Interface not registered
Posted: 19.05.2016, 04:10
by mada7x
I got an error dialog whenever I try to open image files with double click like jpg or png
I can still right click the file and select Open from the context menu though, but it's so inconvenient.
Any fixes? I tried this
https://support.microsoft.com/en-us/kb/835457 but didn't solve the problem. Thanks.
Re: Interface not registered
Posted: 19.05.2016, 16:58
by Zorkoff
Do you get the same error when you try to open the same files with a double click using Window Explorer?
BTW: It might be helpful to know what version of Windows you are using and what version of Free Commander XE.
Posted: 19.05.2016, 18:57
by mada7x
Hi, i am using window 10 pro build 1151(latest?) And the newest version of freecommander. When i double click image file on Explorer, it open the file normally, this only happen in freecommander. Although i can stilll right click the file to open or edit, and it will open Photo Viewer or Paint just fine.
When I ran sfc /scannow, i got a corrupt file that couldn't recover called opencl.dll. I think theres a conflict of nvidia driver and window 10 latest build. I also have java sdk install too. I'm doing a fresh window recovery now.
Posted: 20.05.2016, 05:43
by mada7x
After refreshed the window, the error is gone. I have no idea what software caused this.
Posted: 20.05.2016, 14:56
by Zorkoff
Glad you got the problem sorted out.
